BatteryLogger Pro
Version 1.3
Питали ли сте се как се използва батерията на Вашето устройство? Дали е необходима смяна? BatteryLogger Plus ще отговори на тези и още въпроси от записване на нивото на батерията на заден план * и представяне на данните, които са в графична форма.
Features:
*Smooth and intuitive interface.
* Store and view a virtually unlimited number of measurements.
* Log battery status in the background in iOS4 on supported devices.
* Navigate through all your battery history by dragging, zooming in (double tap), and zooming out (two-finger tap).
* tap any datapoint to view additional details including charge rate, drain rate, and time spent charging the battery.
* view statistics including the load-cycles of your battery and the total amount of watts used.
* keep track of the exact amount of load-cycles of your new iPhone.
* iPad support!
Basic usage instructions:
- new measurements are added whenever the battery-level or battery-state (running on battery, charging, etc.) changes.
- new measurements are added while batteryLogger is in the background*! Just keep the application open to log all battery events.
- navigate the graph by swiping left or right.
- zoom the time scale with a double tap (zoom-in), or a two-finger tap (zoom-out).
- pinch works too!
- view load cycles & more in the 'statistics' tab.
- Using heavy applications? - Check regularly whether the app is still running.
BatteryLogger Plus v1.4
Much more accurate battery-level logging! - now sub-percent accuracy as compared to the former 5%.
More robust screen rotation on the iPad.
More robust stats if the logger has been off for a few hours.
Meaningful error message if there's a problem with userdir permissions (instead of crash).
При мен на iPhone 4 , със 4.3.1 ме изхвърля от приложението.
и при мен изхвърля
Аз я мъча от линка тук, и от Сидия.
Сега ще пробвам и от AppStore или Installous.
