dreaMote Pro е програма, с която можете да поемете изцяло контрола над вашия Dreambox. Предимство пред останалите е това, че можете да си пускате записите от дриймбокса директно на телефона, като ви се дава възможност да използвате BUZZ Player или Oplayer.
img0103l.th.png img0104d.th.png img0105.th.png img0106.th.png img0107j.th.png img0108.th.png img0109n.th.png img0110w.th.png img0111l.th.png img0113p.th.png
Налична за сваляне в iTunes и Installous :)
Появи се нов update: 1.1.1
What's New in Version 1.1.1
- Add standby button to emulated rc
- Allow to search recordings (title and current folder only)
- Allow to set record location to default location manually
- Fix next/previous movie by swiping in alphabetized list
- Fix displaying movies if receiver supports locations
- Fix zapping on iPhone/iPod Touch
Enigma2:
- Support of EPGRefresh-Plugin
- Advanced remote working properly again with newer web interface
Оказа се, че може да се пускат директни стриймове направо от програмата.
Version: 1.1.4
What's new
Enigma2:
- Ask if MediaPlayer should be exited when leaving view
- Allow to show recordings on iPhone with Enigma2 older than February 2009
Neutrino:
- Implemented "Playing" view
What's new in Version 1.1.5
- Disable most animations on armv6 to increase performance
- Quick access to zap-functionality by holding service for 1s (iOS 3.2+ only)
- Fix crash when deleting a movie from the alphabetized movie list
- Fix possible problems with interface orientation on iPad
- Fix problems with canceling refresh of MultiEPG on iPhone/iPod Touch
Enigma2:
- Add SleepTimer-Support (requires WebInterface >= 1.6.5)
- Scroll back to previously playing title when reopening MediaPlayer
- Allow multiple selection when removing tracks from MediaPlayer playlist
- Fix possible crash after leaving list of recordings on iPhone/iPod Touch
- Detect available features more reliably (and hide not supported ones)
- (AutoTimer) Improve support for "avoidDuplicateDescription" (modes 2 and 3 supported)
Neutrino:
- Allow to start an external streaming app (OPlayer (HD) (Lite), BUZZPlayer, yxplayer)
What's New In Version 1.1.6
- "Auto Configuration"-Support (see Help for more information)
- Allow to change Signal Finder refresh interval
- Allow to start streaming or IMDb search from "Playing" view
- Fix another possible crash when deleting a movie from the alphabetized movie list
- Fix picon dimensions on iPhone/iPod Touch in MultiEPG
Neutrino:
- Fix possible crash if picons are missing
Имам един въпрос относно Buzz плейера. Като се опитам да направя zap, ми се отвара Buzz плейера, но в линка, който се показва там ми излиза стандартен порт 8001 за стрийминга, а аз съм форуърднал друг порт в моя рутер. Може ли това да се промени някак?
Благодаря и поздрави.
P.S. Dreamlive вече не става за Satellite BG, защото вече всичко е DVB-S2
Какъв точно forward си направил, от кой към кой порт си го направил, дай повече инфо и ще заработи. Колкото до DVB-S2, това няма отношение към стрийма. Прочети в темата за Dreambox LIVE, предполагам, че него имаш предвид пишейки Dreamlive.
От днес има доста промени в пакета на SatelliteBG. Добавени са нови канали и всичко е на DVB-S2 MPEG4.
При мен се получи един проблем в Dreambox LIVE след добавянето на новите канали. Понеже съм с кофти нет на морето и съм нагласил програмата да ми отваря стриймовете с Low Quality, но чувах само звук а картината я нямаше. Всичко си дойде на място, когато промених Quality да е Middle.
Направил съм forward на порт 8001 към външен порт 18001. Така, като искам да гледам стрийм отвън локалната мрежа, ползвам xxxxxxx.dyndns.xxx:18001...
- Sent from my iPhone using Tapatalk
What's New In Version 1.1.10
- Fix network activity indicator
- Allow to add events to local calendar
- Allow to share events and recorded movies on twitter/facebook/via email
- EPG can be separated by day
- Add optional audio aid to signal finder
- Fix possible problems with MultiEPG on iOS older than 4.0
- Highlight current event in MultiEPG
- Allow to configure length of search history
- Allow to search for titles in regular event list
- Allow to scroll through service in event list using left/right swipes
Enigma2:
- Add last time of refresh to EPGRefresh if backend supports it
- Add support for package management
- Allow to add AutoTimer based on events (from event view)
- Fix missing refresh of AutoTimer list after changes
What's New In Version 1.1.11
Changes in 1.1.11:
- Fix english screen texts
- (Probably) Fix displaying list contents multiple times
What's New In Version 1.1.12
Changes in 1.1.12:
- Fix german screen texts (both are working this time *yay*)
What's New In Version 1.1.13
⚠⚠⚠ This is the last update compatible with iOS 3 ⚠⚠⚠
- Fix possible crash since 1.1.10 if system memory was low
- Sharing to Facebook now has a default text
- Bouquet & Service List more reliable in delegate mode
- Fix Input Alerts on iOS 5
- Fix disappearing exact SNRdb/BER cells in Signal Finder
- Fix search tone of Signal Finder on iOS 3
What's new in Version 1.2.0
!!! Please do NOT update to this version yet !!! ???
- Improve scrolling performance in service list
- Fix possible layout problems right after initial configuration
- Also share event description via email
- Continue to load EPG data for MultiEPG in Background
Enigma2:
- Add Support for Provider list and retrieving all services
- Service Editor available as In-App Purchase
- Allow to add/remove bookmarks
- Fix possible crash in Package Manager on the iPad
- Fix "prefer alternatives" setting in AutoTimer
What's New In Version 1.4.1
- Allow to select default action for zapping (if a stream player is installed)
- Fix starting a stream from movie details
- Smaller stability fixes
What's New in Version 1.4.5
- Voice-Over: Add refresh button to "Currently playing"
- Slight adjustment to multi selection background image in "Blue" theme
- Generic stability improvements
Enigma2:
- Allow to configure streaming port (if a supported player is installed)
- Fix translations in service editor
SVDRP:
- Improve handling of disconnects
