Sun Seeker 3D
Това е програмка с която можете да определите положението на слънцето посредством GPS на вашият iphone.
mzl.diikjcin.320x480-75.jpgmzl.uvgrymdv.320x480-75.jpgmzl.xymtqwxi.320x480-75.jpgmzl.iteyisfx.320x480-75.jpg
Sun Seeker: 3D Augmented Reality Viewer
Description
Provides both a FLAT VIEW COMPASS and an AUGMENTED REALITY CAMERA 3-D VIEW showing the solar path, its hour intervals, its winter and summer solstice paths, rise and set times and more.
Ideal for
* Real Estate Buyers - for finding the sun exposure of properties you are considering
* Gardeners - for finding optimal planting locations for current and seasonal solar exposure
* Photographers - for planning optimal light conditions
* Architects - for getting a feel for the spatial variability of the solar angle throughout the year
* All Sun Lovers! To find the sun, even when it is hidden by clouds or walls
Main Features
* Uses GPS and magnetometer to find the correct solar position and path for your current location
* Flat compass view showing current solar position, diurnal solar angle and elevation (separated into day & night segments), shadow length ratio, atmospheric path thickness
* 3D augmented reality camera overlay view showing the sun's current position, its path with hour points marked
* Camera view also has an optional pointer to guide you towards the current location of the sun
* Ability to choose any date and view solar path for that day
* Additional details including rise, set and culmination times, maximum elevation
* User option to include summer and winter solstice paths on both flat compass view and camera view
Notes
* The compass accuracy depends on having an undistorted magnetic field around your device. If you use it close to metallic objects or electrical equipment, directional accuracy may be impaired.
* The compass accuracy is also reduced when the device is aligned with the local magnetic field vector, so there may be portions of the 3-D view where results are less reliable.
What's new in Version 1.4.1
* v1.4.1
- Fixed bug where sun's path for selected date reverted to today when location update was received.
enJoy;]
