Публикувано Декември 16, 201015 гд This app is designed for both iPhone and iPad $2.99 Category: Games Released: Dec 16, 2010 Version: 1.0 1.0 396 MB Language: English Seller: Trendy Entertainment LLC © 2010 Trendy Entertainment LLC Rated 12+ for the following: Infrequent/Mild Alcohol, Tobacco, or Drug Use or References Frequent/Intense Cartoon or Fantasy Violence Requirements: Compatible with iPhone 3GS, iPhone 4, iPod touch (3rd generation), iPod touch (4th generation), and iPad. Requires iOS 4.2 or later. DoxBG, активни до : Петък 21.01.11. DoxBG Dungeon Defenders: First Wave се задава през декември и ще бъде захранван от Unreal Engine 3 (видео)
Публикувано Януари 4, 201115 гд Ъпдейта(1.1), в който ще има МНОГО подобрения, на 2ри е пратен при епъл и чака одобрение...
Публикувано Януари 19, 201115 гд Автор Dungeon Defenders: First Wave 2.0 DoxBG, активни до : Сряда 02.02.11 What's New in Version 2.0 * iOS 3.2 support! (any iOS from 3.2 & up) * Revolutionary cross-platform play, using GameSpy! GameSpy supports Private Matches, Game Naming, Game Browsing, and an array of search filters. * Familiars/Pets! * Major stability & performance improvements, and new performance-tweaking User Options! * New Missions for the ultimate Heroes * Raised Max Item level to 15, and Max Hero Level to 70 * INSANE Difficulty is much, much harder (and so is HARD)... good luck! * Rebalanced item drops to make super items harder to get * Fixed some leveling & item farming exploits * GameCenter support for private matches, and fixes for Inviting * Better voice chat stability * Various new item drop types * Items now have a level requirement based on their quality, and also tell you which class is necessary to use them in the popup overlay * Big performance boost due to media optimization, and some code optimization * Various gameplay tweaks for a better balance * New Tutorial video explains the game in a minute * Rebalanced item value ramp so that super-items don't sell for ridiculous amounts * Lots of minor bug fixes and game tweaks too numerous to list here... (among the many, Targeting Dummies now print DPS as you're attacking them
Публикувано Януари 21, 201115 гд Не, за съжаление на iPhone 4 4.1 не тръгва, минават клипчетата и ме изхвърля.
Публикувано Януари 21, 201115 гд Кой линк на докс е актуален, защото големината на файловете е различна. 388 и 440 МБ.
Публикувано Януари 21, 201115 гд Които взел , взел ... вече в новата версия има Min req level.... за бронята .... да питам защо толква рядко правят игри през game centre ?
Публикувано Януари 21, 201115 гд Реших преди малко да видим коя е тази игра , която всички хвалите. Дръпнах последния линк от докса и както на колегите по-горе крашва след "клипчето". На 4.1 коя версия да му го туря , някой въобще ако я е подкарал с този фирм. или не се поддържа все още? Редактирано Януари 21, 201115 гд от bokoto
Публикувано Януари 22, 201115 гд Да попитам нещо. Някой които играе онллайн през Game centre получава ли стабилен лаг ? Защото на мен от лаг неможе да се играе нормално. А не е от интернета зашото ми е супер бърз на лаптопа. Немога да си го обесня. Този лаг разваля целия кеф от играта. Редактирано Януари 22, 201115 гд от bgapple
Публикувано Януари 22, 201115 гд Не са я фикснали, както трябва, за по-долните фирмуери... На 4.1.2 - тръгна ми без грешка, нито насича, абе всичко супер ... Върнах сега на 4.1 - тръгва, минават клипчетата и на последното изхвърля! Точно както когато първата версия сам я пригаждах за 4.1 - до там и умира... Някой с по нисък от 4.2.1 фирм да сподели, дали му върви! Благодаря! еми аз съм със iPhone 4 - 4.1 и ми прави същия проблем като на колегите не знам какъв е проблема ? дръпнах версията от ДОХ-а Редактирано Януари 22, 201115 гд от s0urce
Публикувано Януари 22, 201115 гд даммм аз точно заради неговият пост се бях подвел първият път и за това написах и че не тръгва ще се чака и без това друга работа нямаме .
Публикувано Януари 22, 201115 гд Относно играта, аз я играх здравата докато беше на версия 1.0, качих си един squire на ~40лвл, врътнах историята и от там вече ми стана безинтересно, даже и с нови герои. Лъчо ти като си я пробвал как ти вървя на макс графика?
Публикувано Януари 22, 201115 гд Играта се води добра заради онлайн интерфейса и които придава положителна оценка на играта. Не е кои знае колко особена но за IPhone по добра MMORPG не съм цъкал (поне аз).
Публикувано Януари 23, 201115 гд Аз с нетърпение очаквам и PVP версията. Чуда се дали някой ще отвори тема в която да фигурират полезни съвети за развитие на всеки от геройте + бърз leveling и д.р Няма да съм аз този поради простата причина , че не съм и аз много на ясно.
Публикувано Януари 23, 201115 гд Понеже отказваш да си наясно и с някои други неща - ще почиваш известно време.
