Alxx® Публикувано Ноември 10, 2011 Публикувано Ноември 10, 2011 (редактирано) По последно инфо, ънтетърд джейла чука на вратата . Тъй като iOS 5.0.1 идва също, смятам че е редно да прочетете следното предупреждение от dhlizard, мод във iPhone Dev - team forum(преводът не е буквален): Apple is going to release 5.0.1 sooner than later.If you want to get an untethered jailbreak on iOS5, you may need to update to iOS5 (5.0 firmware) before Apple stops signing 5.0 pod2g who believes he has an untethered exploit for 5.0 firmware Tweeted this pod2g pod2g Note about 5.0.1 : don't update if you plan on jbking : the bug Charlie MILLER found can simplify exploits dramatically and will be closed. (This refers to the exploit @0xcharlie recently found in iOS which may simplify any number of exploits) This is a dangerous vulnerability and will need to be patched by hackers after we use it for exploits (as was done with .pdf patchers via Cydia) So you may need to be on 5.0 firmware to get a tethered jailbreak in the future Also remember, there should be an overlap when Apple signs both firmwares for several hours after 5.0.1 is released Do not update to 5.0.1 when it comes out (until the hackers advise otherwise) ! Hashes no longer allow restores to 5.x.x firmware versions (what does this mean ?) If Apple releases 5.0.1 and stops signing 5.0, you can no longer restore or upgrade to 5.0 (except for the short overlap when Apple signs both firmwares) You will be forced to 5.0.1 and may not be able to use the untethered jailbreak ! Flashing the iPad baseband to newer 3GS iPhones Apple has made changes to the newer 3GS iPhones. If you attempt to flash the iPad baseband to one of these newer 3GS phones, it may kill the cellular radio rendering the iPhone useless forever ! Епъл ще пуснат 5.0.1 по - рано от очакваното, така че ако искате ънтетърд джейлбрейк - ще трябва да ъпдейтнете до 5.0(ако още не сте) и да НЕ МИНАВАТЕ на 5.0.1. pod2g е туитнал съобщение, свързано с наскоро откритата от Чарли Милър(@0xcharlie) дупка в защитата на iOS: "Не ъпдейтвайте до 5.0.1, ако планирате да джейлбрейквате. Бъг-ът, открит от @0xcharlie опростява неимоверно пробиването на iOS и скоро ще бъде поправен." Това е опасна уязвимост, която трябва да бъде пачната от хакерите, след като бъде използвана за джейлбрейк(какъвто беше случаят с pdf patcher в Cydia). Така че запомнете: НЕ МИНАВАЙТЕ на 5.0.1 и побързайте да качите 5.0, ако още не сте. Пуснат ли 5.0.1, ще имате на разположение съвсем кратък период, в който Епъл ще подписва и двата фърмуера. Не ъпдейтвайте 5.0.1, освен ако не получите потвърждение от хакерите! Хаш-овете(SHSH) вече не позволяват рестор до произволно избрана версия iOS 5.x.x(какво значи това?): Когато Епъл спре да подписва 5.0, вие няма да можете да качите 5.0 и ще бъдете принудени да качите 5.0.1, тъй като запазването и ползването на shsh вече не върши работа и вероятно ще се лишите от възможността за ънтетърд джейлбрейк!!!. Относно флашването на айпад-ски ББ върху iPhone 3GS, производство след март 2011(Alxx®: мое инфо за датата, може би е валидно и за малко по - стари модели, но в общи линии иде реч за телефони с фабрична 4.3.4/4.3.5): Епъл са нанесли промени в по - новите модели 3GS и флашването на айпад-ски ББ върху такъв телефон(под която и да е версия iOS) може да унищожи напълно радио връзките и да превърне телефона в НЕИЗПОЛЗВАЕМ ЗАВИНАГИ!!! П.П. Лични наблюдения, относно последния абзац: телефоните се прецакват тотално, в 100% от случаите!!! Поради многократно задаване на един и същи въпрос в темата, внимателно прочетете изцяло болднатия абзац от превода, отново и отново, докато не го осъзнаете!!! Редактирано Ноември 14, 2011 от Alxx® 16
zdravko hristov Публикувано Ноември 10, 2011 Публикувано Ноември 10, 2011 Добре, че новината дойде навреме
jh_ivanov Публикувано Ноември 10, 2011 Публикувано Ноември 10, 2011 На това може ли да се вярва. Че аз досега заради унтетъред джейла се въздържам да кача петицата. Акое е вярно да качвам и да чекаме.
Gregg Публикувано Ноември 10, 2011 Публикувано Ноември 10, 2011 (редактирано) Цитат: Хаш-овете(SHSH) вече не позволяват рестор до произволно избрана версия iOS 5.x.x(какво значи това?): Когато Епъл спре да подписва 5.0, вие няма да можете да качите 5.0 и ще бъдете принудени да качите 5.0.1, тъй като запазването и ползването на shsh вече не върши работа и вероятно ще се лишите от възможността за ънтетърд джейлбрейк!!!. Аз нещо не мога да разбера.. Значи ако съм на iOS 5.0 и той вече не се подписва и се омаже телефона от някоя бозава програма от Cydia, тогава няма да може да се прави рестор с 5.0 а се качва на 5.0.1 ? Правилно ли разбирам или нещо бъркам ? Редактирано Ноември 10, 2011 от Gregg
eek Публикувано Ноември 10, 2011 Публикувано Ноември 10, 2011 И аз имам един въпрос относно първия пост. Някой запознат ли е как стоят нещата с ipad-а? Очаква ли се джейл за 5.0 през споменатия експлоит?
Alxx® Публикувано Ноември 10, 2011 Автор Публикувано Ноември 10, 2011 Точно така, @Gregg, правилно си разбрал. П.П.Въпросите: "Кога ще има...?", отнасяйте към врачките - няма как да знаем, засега... 1
VankataBGG Публикувано Ноември 10, 2011 Публикувано Ноември 10, 2011 Дори и при запазен SHSH за 5,0 (3802020277677-iphone2,1-5.0gm.shsh) с tinyumbrella-5.00.12 няма да мога да се връщам на него така ли ???
Gregg Публикувано Ноември 10, 2011 Публикувано Ноември 10, 2011 gorgior , аз попитах това защото едни го разбират под формата на Downgrade на по долна 5.x.x версия. Аз го разбирам като рестор на текущата версия на която е телефона (омазва се на 5.0 / рестор на 5.0). Alxx ми отговори по-горе за което благодаря. Явно бая народ ще се заръщат до 4.3.3 (освен ако и това неорежат някой ден)
Pe6o666 Публикувано Ноември 10, 2011 Публикувано Ноември 10, 2011 Спре ли се една iOS от подписване, всеки рестор с такава си е чист даунгрейд
Gregg Публикувано Ноември 10, 2011 Публикувано Ноември 10, 2011 да явно е така, чудех се как ще затворят слизането от 5.0.1 ..... до 5.0 , а ще може от 5.0 до 4..x.x (и това е даунгрейд), явно има някаква уловка тук
Grievous Публикувано Ноември 10, 2011 Публикувано Ноември 10, 2011 Уловката е, че много хора си накупиха 4S и все още нямат джейл. Много скоро се очаква да излезне 5.0.1 и който не е прочел това, ще се впусне да ъпдейтва. И после как ще върне, като никога не е правил джейл и няма запазени SHSH? Сега капиш?
snooperchi Публикувано Ноември 10, 2011 Публикувано Ноември 10, 2011 Уловката е, че много хора си накупиха 4S и все още нямат джейл. Много скоро се очаква да излезне 5.0.1 и който не е прочел това, ще се впусне да ъпдейтва. И после как ще върне, като никога не е правил джейл и няма запазени SHSH? Сега капиш? А аз имам един въпрос. Ако 4S е на 5.0 ( а той доколкото знам няма на какво друго да е в момента ) и излезе ънтетърд и се джейлне, ще могат да се запазят SHSH-ите и няма да има проблем за връщане, но това ще стане само когато излезе джейл, нали така? И тогава с custom ще може да се ресторне? Или греша? Тоест, ако имам 4с и не минавам на 5.0.1 всичко ще е 6+ и ще мога евентуално после да се върна на него ( след като излезе джейла и си запазя сигнатурите)?
profusion Публикувано Ноември 10, 2011 Публикувано Ноември 10, 2011 кое от "ползването на shsh вече не върши работа"? не се разбира?
sstavrov Публикувано Ноември 10, 2011 Публикувано Ноември 10, 2011 А ние ФЗ-тата какво ще ни съветвате?
Grievous Публикувано Ноември 10, 2011 Публикувано Ноември 10, 2011 Да си купите ФО. Майтапим се. Седиш на каквото си и не мърдаш. 4
sstavrov Публикувано Ноември 10, 2011 Публикувано Ноември 10, 2011 Генерале, слушам. Само теб ще слушам. Стоя и не мърдам. По-нататък пак ще питам. Позззз! П. П. Някой да отключва към шведски оператор? Аз да питам може пък да стане... 1
Kristian.Dinev Публикувано Ноември 10, 2011 Публикувано Ноември 10, 2011 Значи хората с ФЗ телефони да си останем на firmware-a, на който сме си и да чакаме?
Kristian.Dinev Публикувано Ноември 10, 2011 Публикувано Ноември 10, 2011 Сега като излезна 5.0.1, съвсем си нямам идея какво ще правим ФЗ-те и то със FW 4.x.x.
Hcattaneo Публикувано Ноември 10, 2011 Публикувано Ноември 10, 2011 Сега като излезна 5.0.1, съвсем си нямам идея какво ще правим ФЗ-те и то със FW 4.x.x. Е ти си със заключен телефон към Глобул, щом си с глобулска карта за теб телефона си е отключен 1
Kristian.Dinev Публикувано Ноември 10, 2011 Публикувано Ноември 10, 2011 Опа Значи съм разбрал погрешно, извинявам се за глупостта си...
Hcattaneo Публикувано Ноември 10, 2011 Публикувано Ноември 10, 2011 Сега не опитвай да качиш на 5.0 защото няма да можеш, ще ти даде грешка и ще можеш само на 5.0.1. Стой си с 4.x.x.
Alxx® Публикувано Ноември 10, 2011 Автор Публикувано Ноември 10, 2011 Напротив, опитай! Няколко часа се подписват и двата фърма. Ако гризнеш дървото, не качвай 5.0.1, а просто го изкарай от рикавъри с ъмбрела.
Hcattaneo Публикувано Ноември 10, 2011 Публикувано Ноември 10, 2011 Дано да чете в момента какво му пишеш
